LS Series Tech 1998-2002
help me with my tires i have a question?
Old 05-06-2007 | 11:27 AM
Lee Willis's Avatar
Default RE: help me with my tires i have a question?
Then think twice about drag radials. I run BFG drag radials on both the 'vette (345s) and Camaro (315s)and get only 5-6K miles per set (and I am NOT doing burnouts, etc.). I point: you absolutely cannot drive the car on a wet road with drag radials -- therear will hydroplane on a film of moisture.
By banging a bit on the rear fender liners and grinding down one bolt bracket 3/16 inch you can fit up to 315s in the rear (helps to have wider wheels -- we put the stock ZO6 wheels on the Camaro - 10.5 inch wide in the rear). 315 or 305 treaded tires with a soft compound will do much better in a launch than stock, and you can still use it as a daily driver if you have to.
Old 05-06-2007 | 09:20 PM
o2camaross's Avatar
If you are looking to get ZR1's then make sure they have the 50 mm offset and you won't have to bend or grind anything. I have 17x11 ZR1's with Nitto drag radials and they hook and look good. They actually have amazing grip when its wet
Puddy
10-12-2012 04:28 AM
JPrice
05-20-2012 03:48 PM
thefley
02-20-2012 06:37 PM
86Iroc-Z28
12-17-2010 08:57 PM
imcdowel
03-12-2010 12:02 PM
Quick Reply: help me with my tires i have a question?
