LS Series Tech 1998-2002
Good deal???
Old Jun 26, 2010 | 03:31 PM
DarkKnight's Avatar
GTO Killer
LimeKnight
Default Good deal???
Ls6 ported intake manifold
Ls6 ported and polished 85 Mm TB
For $425 Sounds good to me...
Oh and is it a must to run an 85 MM mass air flow????
Old Jun 27, 2010 | 07:00 AM
maudyZ28's Avatar
yeah sounds like a good deal dude, just make sure you dont break the oil pressure senosr when you fit it also make sure the cam on the throttle body is the same as it opens at a different rate on some TBs. My 99 has small cam and different colour spring than a 2001, you'd have to check your or swap then over if needed.
You dont need the MAF as long as you can get a pipe to joint the TB to your MAF, if you did get the MAF you would need to calibrate it but you have HP tuners? so it can be done
Old Jun 27, 2010 | 11:11 AM
DarkKnight's Avatar
GTO Killer
LimeKnight
the tb has the same cam as my car... he already told me cuz he had it an a 2000 z
Old Jun 27, 2010 | 11:20 AM
maudyZ28's Avatar
get it then
it wont make much noticeable difference but defo with help breathing and if you get cam, heads later its worth it
Old Jun 27, 2010 | 11:42 AM
DarkKnight's Avatar
GTO Killer
LimeKnight
idk if i wanna do cam first or the intake
Old Jun 27, 2010 | 03:34 PM
maudyZ28's Avatar
for the best results get the cam and stuff, but get the springs and push rods too, TSP do some good packages from $589 - 689 depending on which springs you chose. You'll defo notice the 20-30 bhp a cam gives over the ls6 intake on a stock engine. I did not notice anything really, car is faster but got headers etc and got ls6 to get rid of egr
Old Jun 27, 2010 | 03:42 PM
DarkKnight's Avatar
GTO Killer
LimeKnight
yeah i might just do cam first
Javs_is_fat
Aug 12, 2011 05:39 PM
c4maro
Aug 6, 2009 11:30 AM
Andross
Feb 5, 2007 07:55 PM
fiad06
LS Series Tech
Nov 27, 2006 06:58 PM
