LS Series Tech 1998-2002
Engine Issue
Old Feb 7, 2012 | 05:00 PM
SilverBlueLS1's Avatar
Default Engine Issue
Ok. So something is again going wrong with my car.
I was driving to get lunch and she started chugging and lurching again. Then the engine died. It turned over and started, with a little gas pedal, but wouldn't idle.
She will idle now, but it is really rough and there is a clicking coming from one of the valves. A lot of exhaust noise and smell.
I haven't really gotten on the car recently. I don't recall scrapping the exhaust on anything.
Any ideas?
Old Feb 8, 2012 | 02:09 PM
Clicking from the valve area could be a valve train problem, or just an exhaust leak, being that you mentioned exhaust noise and smell. Pull the valve cover and see what is going on under there.
Old Feb 8, 2012 | 02:28 PM
Cheeks's Avatar
August 2011 ROTM
might've had a rocker come loose, grab an 10mm and 8mm socket, take teh coils and valve cover off and have a look see
Old Feb 8, 2012 | 08:14 PM
Would a loose rocker cause those issues?
Old Feb 15, 2012 | 10:32 PM
Turns out that the years of hard owners and abuse have caught up.
The car broke 2 valve springs.
I am getting new ls6 valve springs, valves, milling the heads, and fresh fluids.
Hopefully the car will run a lot better.
Craig Ferguson
Apr 7, 2015 08:16 AM
DanielB
Mar 6, 2012 11:23 PM
unoste
Mar 23, 2011 02:17 AM
duanesss
2010+ V8 Tech
Jun 13, 2010 08:21 AM
steveh3500
Apr 12, 2010 11:53 AM
