LS Series Tech 1998-2002
e85 conversion
Old Dec 22, 2010 | 02:51 PM
myzsmybaby's Avatar
Default e85 conversion
im debating doing an e85 conversion kit on my car 2000 z28 does anyone know anything tht could help me out? cost, effectiveness, difficulty. thanks yall
Old Dec 22, 2010 | 06:03 PM
Should run OK with larger injectors and PCM reprogramming. However, alcohol attacks certain metals, and you may wind up with some serious fuel leaks and parts failures.
Old Jan 24, 2011 | 09:39 AM
Nick B's Avatar
Don't be surprised if you end up having to replace your rubber lines. And you will have to replace the fuel filter atleast a time or two, e85 is a solvent and will pick up any junk you have in your tank/filter and likely end up clogging the filter.
NEVERLETITDIE
Mar 8, 2010 11:06 PM
RubberDucky
May 8, 2009 04:42 PM
stangslayer
Dec 19, 2007 02:31 PM
davefh
Aug 6, 2007 08:40 PM
davefh
Apr 3, 2007 10:05 PM
