LS Series Tech 1998-2002
Delayed starting
Old May 10, 2014 | 04:24 PM
GaryDoug's Avatar
Get a 12" jumper wire and have it ready the next time. When it happens, remove the relay and jumper from the red terminal block (12v) to pin 87 of the relay socket. The starter should operate. I would use a small screwdriver stuck in pin 87 as a contact to keep from damaging the socket. No starter = bad wire from relay to starter.
Old May 10, 2014 | 07:04 PM
have you tried the old tilt the steering wheel up or down trick
Old May 11, 2014 | 11:22 AM
HappySalesman's Avatar
Steering wheel tilt? What, just tilt the steering wheel up and dowm as I try to start it?
Old May 11, 2014 | 03:10 PM
yep. sometimes the wiring or the ignition switch linkage is damaged or out of adjustment inside the column and that makes a difference.
sparky555
Aug 29, 2010 11:18 AM
kashdog1
Jul 4, 2010 02:16 AM
libertyforall1776
Nov 18, 2008 12:41 PM
