LS Series Tech 1998-2002
Battery Drain While Driving
Old Sep 28, 2010 | 03:26 AM
98VortechSS's Avatar
Default Battery Drain While Driving
I have a 98 SS LS1 with a vortech supercharger and have been running into quite a few strange problems that I hope someone can assist me with. I am having a problem with the cars charging system. When the car is just idling it can usually maintain 14v, but as soon as I begin driving it starts dropping slowly and can get as low as 12v. I have had the alternator tested and verified good. I have removed the positive terminal to see if the car would die, but it maintains voltage. I am seeing a 2.5amp draw with the car off. I have pulled every fuse in an attempt to locate the draw, but it still remains. It seems to be from one of the 3 fusible links by the second fuse block in the engine compartment. I have gone through alldata, but they only describe the location and not what they feed. My battery has been relocated to the trunk, but I have verified all connections to the battery. I have removed the power from the started to see if that was the draw, but it wasn't. I have tried 3 different batteries with the same results. The ASR off light always comes on as well and I can't turn it on. The switch seems to be getting hot.
I am also having a problem with the idle at times running high (1500 rpm +-200). Not sure if this has anything to do with the voltage though. The car has had quite a few modifications done that I don't even know about. I have been unable to find a shop around me that will even look into it. Any help will be greatly appreciated.
Known Mods:
Vortech supercharger with power cooler
Oil pump upgrade
1.7 roller rockers
trickflow pushrods
walbro 255 fuel pump
Long tube headers
high flow cats
upgraded cam
Probably more I'm unaware of.
BZpbp
Nov 7, 2012 09:22 AM
jpucci
Aug 19, 2007 08:56 PM
jpucci
Jul 17, 2007 09:54 PM
86 camaro
Jun 8, 2007 01:28 AM
Tom97V6
Apr 7, 2006 06:40 PM
