ARH Stepped Headers & Catted Y Arrived!
#21
^ Yes, rear O2 bungs are included on their catted y-pipe as you can see in the picture above, and it is worth noting if you want any extra bungs added like for a Wideband, they typically will add them at no cost...
But you could also put plugs in them and use emulators, or with a tune just delete the ones after the cats, since they are emissions-only and serve no other function.
#22
Yeah that's what I've read because the rears don't really do anything other than be a tattler. I've also heard that even with the rear o2 in place the check engine light will still kick on because they read for stock manifold and car
#24
Yeah idk of if it will or not. I've been reading so many different threads on ls1 tech that it sometimes gets confusing. I hopefully plan to order my set in about a month. That will give me time to get my ls6 intake already to go on. Gonna sand it smooth and paint it. Who did you go thru on ordering the headers?
#25
^ WS6Store.com
So the SS is out of the shop -- more muscular sound and feel, and no SES codes thus far! As the picture below implies, the fit is tight between the 1 7/8ths section of the headers and the K-Member on the driver side. The result is the headers touch and make noise at some points with certain movements and RPMs due to this, not sure if this is a convertible-specific issue -- maybe I should have stuck with 1 3/4... The shop did a little grinding of the K-Member corner, but it will have to go back for some more adjustment. I am also going to phone ARH to see what they have to say...
The Noweeds diverter is top notch -- very nice operation, fully automatic, wicked sound.
#27
Looks like the solution is the grind the $&!+ out of the K-Member in this area of touching from this post: LS1TECH - View Single Post - American racing headers 1 7/8 and starter doing battle!!!!
#28
Yeah I don't want grind on my k member I plan wayyyy down the road when the 98 gets pulled from daily duty to pull her apart and do everything. Because I'd like to have a bone stock camaro (68) and one where there's no much stock left (98) besides my 98 is a base ss no other options doesn't even have leather just good ol cloth
