LS Series Tech 1998-2002
angel eyes head lights
Old Nov 11, 2006 | 05:10 PM
00BlackBullet's Avatar
Default angel eyes head lights
anyone on here have the angel eyes head lights? Im curious about how you would control the lights. Can you turn on the halo's only? How would you? Would I need to install a switch for them? Also, anyone have pics if they have them installed? I would like to see the differance between the black ones and the silver ones installed and not on a shelf. Anyone hear anything bad about them?
Any thoughts would be nice
Old Nov 11, 2006 | 09:21 PM
shnormo's Avatar
Default RE: angel eyes head lights
They look pretty cool. You can wire them in several different ways. You can have them hooked up to your regular head lights, a separate switch, with your first click of your headlight switch, or with your car's ignition. You can turn on the halos only by a separate switch. Run a fused power wire to a switch through a body grommet, and then find a place to mount your switch, and then drill out the hole for it to go into. After that run another wire off the other terminal on the switch to the power wire on the halos. Ground the halos with any of the other lights or to the body by extending the ground wire.
Old Nov 12, 2006 | 04:29 AM
thanks! any opinion on the black ones or silver? my Z is black so i dont know? i think the black might be too much black!
Old Nov 12, 2006 | 01:19 PM
shnormo's Avatar
I personally like black on black. If you have more silver accents, then I'd go with silver.
Old Nov 12, 2006 | 04:44 PM
Well im gonna get the "camaro" inserts for the *** end. They are mirrored from SSinserts.com. Maybe replace the Z28 emblums on the sides as well.
Lightwurkz
Dec 11, 2010 04:03 PM
SixShooterCamaro
Dec 14, 2009 04:34 PM
purpl96
12
Nov 11, 2007 07:35 PM
billyss2002
Aug 27, 2007 12:34 PM
dragonoz
Apr 20, 2007 01:27 AM
