-   LS Series Tech (https://camaroforums.com/forum/ls-series-tech-15/)
-   -   AC Compressor Replacement (https://camaroforums.com/forum/ls-series-tech-15/ac-compressor-replacement-63413/)
Buffalo02Z28 Jul 18, 2011 02:12 PM
So my AC is failing and its come time to replace the AC compressor. A shop was going to charge me $700 for parts and labor to fix my AC, but I'm not paying that. I'm going to need some some tips on how to do this. A step-by-step how to would be nice. How tough of a job is this?
z28pete Jul 18, 2011 03:21 PM
Changing the compressor itself is no big deal. But when you disconnect the AC hoses all of the refrigerant is going to blow out, and most likely taking the lubricant with it. Depending on how the compressor failed there may be shrapnel left in the system which can come back and haunt you at a later time, unless it is cleaned out. After the parts are replaced, including the receiver/drier, the system evacuated with a pump to get all moisture out, and refilled with the right amount of refrigerant and lubricant, it will have to be tested for leaks.
torque_is_good Jul 18, 2011 06:06 PM
it's been A/C summer for me as 3 of my vehicles all required parts to be replaced. My 3rd gen needed the full monty. What Pete said is correct. There are of course back yard methods but that would not be eco-friendly to discuss.
FWIW, I did the work on all 3 of the vehicles in my home's garage. Be sure to get a new orifice if you are doing it yourself and it takes 2 cans of R134A to fill the system. They are $9 at Wal Mart vs $20 per can at the parts store. if you need a new compressor, it may already come with pag oil or have a bottle with it. You do need to add some into the dryer (accumulator)
Buffalo02Z28 Jul 18, 2011 07:07 PM
Thank you guys for the responses. I'm going to drop the car off at this shop tomorrow to have them do it. The AC kit that I planned on purchasing was going to cost $400, but the shop is going to repair my AC for $600. I think that its a good deal and this shop also specializes in F-bodies, so they're very familiar with these cars.
BasicConcepts Jul 18, 2011 07:09 PM
400s a good price for a compressor and what ever else you get the comp for my 3.4 was like 475 just for the compressor but 600 for an new r/r plus a warranty and a filled system thats pretty good
Gorn Jul 18, 2011 07:52 PM
What failed on the compressor? Did it get loud or does it just leak? If the compressor ripped itself apart you have metal all through the system. Thats a pretty big job for a newb. You have to get all the metal out or you could wipe out the new compressor.
There is a chart in the GM manual that list all the add oils number. But with the compressor you are supost to drain the oil out of the old compressor and measure it. Then add that that amount to the new compressor. If you drain the system and there is less then 2 oz then you need to add a min of 2 oz. This assumes you slow drained the freon out and did not lose any oil.
Your going to need a vacuum pump and set of AC manifold gages. After you get all the mechainical fixed you and the oil replaced as needed
Pulling down the system
‪How to evacuate and "pull" vacuum on an R134a car AC system‬‏ - YouTube
Once the system is pulled down it is ready to be charges. There should be a AC tag in your engine compartment that list the amout of freon your system takes, You should replace the dryer/reciever and the filter. good luck.
Buffalo02Z28 Jul 18, 2011 08:42 PM
I'm pretty sure that the compressor ripped itself apart. There were was nothing leaking and when I turned the AC on, it was loud and blew some dust into the interior of the car.
BasicConcepts Jul 18, 2011 09:17 PM
try it without the ac on that sounds more like a blower motor
Buffalo02Z28 Jul 18, 2011 09:32 PM
Haha, it does. It makes a lot of noise.
Gorn Jul 18, 2011 09:35 PM
Well there is no way a compressor can have an effect on the inside of your car. For that to happen you would have to blow either your expansion valve or the evaporator. Does ther copressor turn anymore? Sounds like you might have a big project on your hands. Maybe not the best to try and learn on. Buying the above tools for one high risk repair does not make a lot of sense.
