LS Series Tech 1998-2002
98 ls1 keeps popping o-ring off regulator
Old Nov 13, 2010 | 01:06 PM
ryans95z's Avatar
Default 98 ls1 keeps popping o-ring off regulator
I just bought a 98 z28, and for some reason it keeps popping the o-ring off the fuel regulator and will cut out realllly bad when accelerating. when i put the o-ring back on the car will run perfectly for about 30 minutes even when put to the floor, and then it pops the o-ring off and cuts in and out. Any ideas at all???? My mods are New 255 fuel pump, Wet kit adj from 50-150 shot with botlte heater, headers, and some other bolt ons. The nos was on car when i bought it and is coming off. I really need some help on this one guys.
Old Nov 13, 2010 | 03:15 PM
whats the fuel pressure set at?
Old Nov 13, 2010 | 04:28 PM
ryans95z's Avatar
it reads 58psi at idle
Old Nov 13, 2010 | 04:43 PM
is that with the fpr unhooked? do you have an ajustable fpr? might try a oversized o ring.
Old Nov 13, 2010 | 04:52 PM
ryans95z's Avatar
no, that is with it hooked up and the o-ring on,at idle. when it comes off the fuel pressure will go down to like 40psi and be sluggish and hard to start. when the o ring is on its just fine. just cant figure out what can cause the o ring to keep coming off. could i use some silicone to hold it on?
Old Nov 13, 2010 | 05:04 PM
are you sure you got the right fpr? did a quick look and the 98 seems to have a fpr only used in the 98.
http://www.summitracing.com/parts/NA...RO&prefilter=1
Old Nov 13, 2010 | 05:05 PM
ryans95z's Avatar
what are your thoughts on silicone'ing the oring on there, or maybe hose clamping it??
ryans95z's Avatar
ya, it was doing popping the orings, and then i bought a new fpr and its doing the same thing
Old Nov 13, 2010 | 05:13 PM
ryans95z's Avatar
do you think it would hurt anything to use silicone on the oring or just hose clamp it??
Old Nov 13, 2010 | 05:35 PM
did some more looking and it looks like 98 is a transition yr and your fpr is most likely in the tank and that thing is a balancer, is there a return line hooked to it that goes back to the fuel tank? if not its not a fpr but a balancer. if you can get a clamp on it give it a try.
