LS Series Tech 1998-2002
2001 lifter clatter
Old Jan 4, 2007 | 01:42 PM
nitrojunkie's Avatar
Default 2001 lifter clatter
I figured this would have been posted already. I searched as much as I could before posting, so if this is a repeat post,I appologize.
My '01 Z28 (6-speed) has a noisy lifter. The damn dealer must have ran a noisy lifter treatment. First oil change I did, the tap-tap-tap started. Its very faint and only at idle (and as a mechanic I can say it's clearly a lifter noise). My hunch is someone tried to race itand downshifted to scond instead of fourth and over-revved it. As such, it's probably a bent pushrod, but could be the lifter too.There is a TSB for this... TSB #020601038. Anyone have access to these and want to be a super-cool human being and zip me the info?
Also, I've never torn into an LS1 (although I can rebuild a pre-87 or vortecSBC in my sleep). Rumor has it, the stock rockers are non-adjustable. If so, this may be the time for a cam and lifters as well as some roller-rockers rather than getting stock replacements from a dealer. Anyone know of some roller-rockers that will fit under the PCV baffles?
Old Jan 4, 2007 | 03:05 PM
JD1969's Avatar
Default RE: 2001 lifter clatter
Most likley it is a bent push rod, LS1 lifters rarley fail as they are a pretty nice roller peice. The stock rockers are non-adjustible, but are preety good units actually, I am still running them as well as stock lifters. Sorry I do not know of any TSB's for a lifter
kdj6930
Oct 16, 2013 05:38 AM
jasunf
May 28, 2010 08:46 PM
MTRIMBOLI
Apr 30, 2010 07:46 PM
jagman4544
Nov 15, 2007 04:11 PM
MRCHUNK
LS Series Tech
Jun 24, 2007 06:28 PM
