2000 Z28 speaker help?
i was considering putting some stereo speakers i have left from some small stereo speakers int he front door pannels of my 00 z28 but is there a trick to taking off those plastic grill covers for the speakers.. because i had a hard time getting them off in the front atleast (back is easy)
I just replaced the speakers in my doors a month or so ago. It really is pretty easy taking the door pannels off. Remove the screws that you see in the door panel. There are 3 (I think) in the arm rest, 1 in the plastic piece that surrounds the lock slide. ANd one more in the plastic triangle piece that would be the cover for the side mirror mounting bolts. Once the screws are removed then with a little effort, gently lift straight up on the door panel, you should feel it give. The way the door panel is designed, is that it has several clips along the bottom that set down inside the door sheet metal. So if you use an up and out motion, it should be fairly simple.
SHOULD be fairly simple. I removed all the screws and pulled on the door, but I didn't put too much effort because the LAST thing I need is to break my damn door, I'll go try again though ! wish me luck!
