2000 Z28 Fog Lights?
I have a 2000 Z28 Camaro that did not come with fog lights. I have found a set of OEM lights but wanted to ask and see if anyone knew if the wiring is there. I know with most cars if you do not get and option such as this the factory will run the wires just not put the part on. If this the case with the Camaro?
Does the car have a fog lite switch? In most cars wiring is provided for options even if they are not installed. Poke around in the general area where the fog lites mount & see if you can find any wires with connectors on the end that are not being used.
91 RS
Feb 24, 2007 11:14 PM
