LS Series Tech 1998-2002
01 camaro problems! help
Old Oct 22, 2011 | 08:17 PM
01ssls1's Avatar
Default 01 camaro problems! help
I have an 01 Camaro SS ls1 and I've had it about 8 months. When I picked it up I knew the previous owner had abused it! But it seems like everything I fix more comes up!
it has 92k and the plugs and wires had never been changed. So I did a tune up plugs wires, intake gasket, all fluids and cleaned the slp mass air flow, throttle body, all connectors and it was running great!! Now my check engine light is on. 3 codes came up
P0141, p0161 and p1637. The first two say downstream o2 sensors? Could that be cause from the after market mass air flow? And the third one is something with alternator but it tests good?
Any help will be appreciated!!!!
thank you in advance
Old Oct 23, 2011 | 08:18 AM
Psycho's Avatar
No. The O2 sensor is bad. Replace it, or have it tuned out. It is not essential for good performance.
See what that does for performance, then if the alternator code persists, you will have to dig deeper.
Old Oct 27, 2011 | 12:06 AM
shawnathan's Avatar
What kind of test did you perform on the alternator? Also be sure you connected all your plug wires well if you have loose ones you could not be getting spark and your o2 sensors will be reading that way because you have "rich" condition because the fuel is not burning at all or is not burning completely. You can also check for terminal tension on the coil packs if you diabled those while replacing your plugs. Or it could be excessive spark plug gaps. I wouldn't jump straight to replacing the sensors without checking that first. That just sounds like something a dealership would tell you to do :S. No offense.
Old Oct 27, 2011 | 12:54 PM
01ssls1's Avatar
I used the tester at kragen. And ill check to make sure my wires are snapped on all the way. And the plug gap is normal
Old Oct 27, 2011 | 01:40 PM
shawnathan's Avatar
Idk what that is do they use a vat machine there or just a diode tester? Did you have the codes before you did the work to it?
Old Oct 29, 2011 | 09:09 PM
01ssls1's Avatar
I only had the alt code before hand
Old Oct 29, 2011 | 09:17 PM
shawnathan's Avatar
Hook a dmn up to the positive and neg terminals on the battery and check for ac voltage to make sure your diodes are working correctly. Find anything with your wires?
Old Oct 31, 2011 | 12:31 PM
01ssls1's Avatar
What's a dmn and the wires are fine
Old Oct 31, 2011 | 08:15 PM
shawnathan's Avatar
Digital multi meter.
Old Oct 31, 2011 | 08:47 PM
shawnathan's Avatar
It's gotta be something you did. Is it both downstream sensors or just one?
