replacing intake manifold gasket...suggestions
i am going to be replacing the intake manifold gaskets, should i replace the PCV valve during this time ?
RE: replacing intake manifold gasket...suggestions
PCV valve is a $5 item. Just change it out.
Replacing the intake manifold gasket is a major job and why do you think it needs replacing??? PCV valve is a one minute job at most. Also your question containing these two items makes me wonder if you don't mean the EGR valve?????
its not that major of a job, jsut take your time and make sure you clean everything you see, it makes it look better as well, and make sure you buy the metal fuel line disconnect tool, i bought the cheap plastic ones, and they were not strong enough, that was the worst part for me, and making sure it goes straight on when re-assembling.
did you check out that page under shoebox they have a whole walkthrough of how to properly do it. o and yea, you my as well change out all the valves you can, that way you know its all good. |
well i know i need to have the gaskets changed because the intake manifold is leaking, i plan to replace the valves when i replace the valve cover gaskets
nothing to do with the intake gaskets but I have never had to relpace a PCV on a car of my own. my friends have had them clog and all I do is clean them out with WD-40 and they are good to go.
you can tell if it is bad by shaking it. if you hear nothing moving then you know it is clogged |
Yes, just do it. $5 item .
ORIGINAL: Alih well i know i need to have the gaskets changed because the intake manifold is leaking, i plan to replace the valves when i replace the valve cover gaskets |
well my friend works at a shop near my house and he does most of the work on my car, he also has a firebird so he knows quite a bit about fbodies and LT1s, i dont think im gonna do the valves maybe later down the line when i put new heads in
well i just had the new intake gaskets put in as well as vacuum lines and it sounds mean:D even with the stock exhaust
