ram air
Old Mar 12, 2008 | 11:10 PM
tman21786's Avatar
Default ram air
so i am putting an order in for a new ram air hood and ram air interface air box kit to make it functional of course.. so my question is.. does it matter which one i install first.. or should i install one of the two first to assure proper line up.. right now i have the stock z28 set up
Old Mar 13, 2008 | 12:47 AM
95slvrZ28's Avatar
Default RE: ram air
To my knowledge it doesn't matter which one you install first, although if you install the air box before the hood you may have some clearance issues (just speculating on that one, I've never actually done a swap). Good luck with it!
Old Mar 13, 2008 | 12:52 AM
SpecterGT260's Avatar
Ninja Administrator
Default RE: ram air
in theory they should just line up. but that never happens [:@]
I would personally do the hood first, get that on and sitting irght, and then put on the air box. however the rubber peices usually have enough slop in there that it will have to be way off to cause a problem
Old Mar 14, 2008 | 12:04 PM
tman21786's Avatar
Default RE: ram air
ok il do the hood first.. is it really worth an extra $300 to put the air box kit in tho? i mean im putting it in ayways but would u say its worth it
