installing headers
Old Feb 5, 2007 | 04:45 PM
Saint_Ali's Avatar
Default installing headers
im going to be installing long tube headers and my question is do i need header fasteners ?
Old Feb 5, 2007 | 07:06 PM
95slvrZ28's Avatar
Default RE: installing headers
You'll need header bolts. In my case, they came with the headers, but I suppose it could depend on who you get your headers from. Mine were all 3/8ths 12 point bolts. If your headers don't come with the bolts, you'll probably also have to order header gaskets seprately also.
Old Feb 6, 2007 | 05:28 AM
Saint_Ali's Avatar
im getting hooker header, they do come with gaskets and bolts but under suggested parts from summit they reccomended header fasteners and i never installed headers before so was just curious
Old Feb 6, 2007 | 02:19 PM
You could replace the header bolts with hardened allen bolts. Then you will have a lot more room to work with. Just make sure they are hardned.
Old Feb 6, 2007 | 07:22 PM
95slvrZ28's Avatar
Let us know how the install goes...
Old Feb 10, 2007 | 12:15 AM
Saint_Ali's Avatar
i will, i already have the y-pipe and header reducers, long tube headers are on the way, should be here in 3-4 days, i cant wait
Old Feb 10, 2007 | 12:29 AM
74454bb's Avatar
May 2007 ROTM
Throw away the gaskets and get a good set,or use factory exhaust manifold gasket. If not youll be changin them in a few months. The hooker bolts should do fine.
Old Feb 10, 2007 | 04:43 PM
95slvrZ28's Avatar
Actually, the hooker headers may come with a decent gasket(my uncle got a set of Hooker super comps and they came with Mr. Gasket company grafoil gaskets). If you're looking into new gaskets, I'd more than suggest these, grafoil is about the best gasket material you can get. I'd suggest not utilizing the old manifold gaskets, in the least, go and get some Fel-pros or Mr. Gasket co. from your local Advanced Autoparts or something like that.
Old Feb 10, 2007 | 05:23 PM
74454bb's Avatar
May 2007 ROTM
I ment new factory gaskets,and if they come with the paper gaskets don't use those. If you get lucky youll get the good ones.
Old Feb 11, 2007 | 02:53 AM
bowtieguy's Avatar
July 2009 ROTM
the best header gasket i used to use were the rebuilder gaskets you got in the master gasket set, they were dark gray almost black on one side and on the other side they were chrome colored and i guess you would call them perforated because they had little holes in them.they were the best,never had one blow out and even used them over and over.they come 3 gaskets per side,not long for the whole side.i used to race 3wheelers and we would beat and pound on them all weekend long and we found out that somestock parts outlasted the aftermarket parts.trial and error is the best method unless someone that has already done this is telling you what to do.inexperience needs to learn from experience,saves alot of headache and money.
