Holley Carburetor Hlp
Old May 11, 2012 | 08:07 PM
1860Surveyor's Avatar
Default Holley Carburetor Hlp
1969 camaro 427 stroker full roller high duration cam with 900 cfm holley, not sure of model but have been told it looks like street eliminator or demon? Duel feed duel pumper.
Problem is it idles too rich. I have the idle mixture screws out only one full turn, still get black smoke. Today I went to check the float levels and the rear bowl was dry. Front was set correctly. I am suspecting that fuel is bypassing somewhere in the rear metering plate or somewhere from this back bowl creating the rich idle problem.
This would also explain why even with no choke on the carburetor it will start immediately without touching the gas pedal.
Any ideas? Thanks.
Old May 13, 2012 | 04:38 PM
Found the problem, whoever built the engine installed edlebrock high volume high pressre fuel pump. Pushing 10 psi, blowing it right thru the carb.
Bjm3.8
Oct 19, 2010 08:07 PM
logankarshner
Dec 13, 2009 03:19 PM
NYH1
Jul 26, 2009 10:09 PM
jason14227
Jan 31, 2008 11:42 PM
firefighter47
Apr 12, 2005 09:14 AM
