99 CAMARO 3.8 MAKES A RATTLE SOUND HELP PLEASE
i have no idea what can be wrong with it today i went to go get a new cat and dual flowmaster muffler cuz i was told i had a bad cat and it plugged up the muffler took it down and asked if its just the cat or also the muffler was told both had to go even showed me the cat and it was all messed up spent about 700 and drive off and the rattle is still there i was hella mad i went right back and said it still rattles and it drives hella bad now it was hella rough so he then shows me that the spark plug wire was exposed from being melted from the exhaust manifold and it was makin a spark, and said the engine might just be old and sometimes that happends butit only has 80,000 miles but is old.now im gettin that changed but what can this rattle be?
RE: 99 CAMARO 3.8 MAKES A RATTLE SOUND HELP PLEASE
You from Cali? My ex was from Cali and used to say "hella" all the time. Anyways, check the heat shields on the exhaust, and make sure they're not loose.
I know the heat shield on my cat rattles,the cat itself is fine its just the heat sheild, that or the starter heat shield.... and yes i know i spelled sheeld 2 different ways i dont remember how....
The heat shield on my cat use to rattle. I tried tightening it, but ended up taking it off, no morerattle. If you do that just don't park overanything flammablethat will be directly touching your cat.
ORIGINAL: red94v6 I know the heat shield on my cat rattles,the cat itself is fine its just the heat sheild, that or the starter heat shield.... and yes i know i spelled sheeld 2 different ways i dont remember how.... |
alright so i did some more research on this noise the other day and found out that it seems to be coming from the area next to the transmission or is the transmission, it was very strange i jacked it up both rear wheels off the ground put it in drive since that is most of the time it only happens when you first take off when im on the freeway you dont hear it that much its a automatic by the way, and it wasnt there i thought to myself thats strange the sound is gone lowered the car back on the ground and put it in reverse in my drive way sound never happens in reverse put it in drive and heard it again its very loud as soon as you put your foot on the gas and gets more quite as you go faster , and to the guy asking if i was from california yea im from the bay hella people in northern california mostly say hella
im starting to think this isnt a exhaust problem maybe a transmission problem |
My car did the same thing until i took it to a muffler shop. If u ever bottomed ur car our thats your problem. The problem with mine was that black bar that went across my muffler. It was bowed in. so he had to wedge it out with a crow bar and no more sounds after thant
a spark plug wire is not going to make it rattle, melted or not, it can cause a misfire which will cause a jerking and hesitation, the rattle sounds like a broken hanger wire or somthing underneath. Check your shock covers also, I had mine come loose a few years ago and made a rattle sound at idle and low speeds due to the vibrations, its not the tranny itself as if it was rattling, then somthing SERIOUSLY wrong would be causing it, and therefore would not shift properly... Somthing underneath is loose...
Can you get a video and try to lift the car and make it happen again? If I can hear it i can tell you whats wrong,
The cross member on the bottom. You'll see it run right below your exhaust right under your passenger side. The stock cat sits right on top of it and doesn't rattle. Mine did the same thing when I removed my cat. You just have to remove it. It doesn't hurt anything
