78 exhaust and headers
Hey guys, I'm new to Camaros. Just looking for some input and help.
My 78 Z28 has a bone stock engine and a 4 speed. I previously had an 86 442 with a 74 Olds 350 in it with true duals and headers and you could hear it coming up the block and sounded great. I'm looking for that kind of sound with my new Z28, especially since you don't really hear it 10 feet away. Is it too tight for headers in there? and is it even worth it since it's a low compression/low hp motor? I was looking into a mandrel bent pypes system and flowmaster 40s since I don't want cats. Any help or input would be appreciated. |
If you're going to go with Flowmaster 40 series mufflers, why not just go with their complete exhaust system? A lot of their systems say they'll fit '67-'74 or '70-'74 but they'll fit '67-'81 or '70-'81 Camaro and Firebirds.
I went with the Flowmaster 2 1/2" dual exhaust system that uses the single transverse flow muffler that go's between the rear end and gas tank. It has more ground clearance. It has the deep Flowmaster sound. Honestly, it's a little louder then I thought it would be. Not to bad though. You're going to have to buy a set of headers that will work with your 4 speed. Maybe Summit, Jegs and whoever elses web site will have that info. Or look at the manufactures web site or call them. Good luck! |
Is it worth it? Really, did you ask that?
Its still a 350, cam, carb intake, exhaust and your not in the low hp range any more. They fit fine, and its flowmasters or your a noob. If you really broke they make some knock-offs, but get flowmasters. |
You're going to have to buy a set of headers that will work with your 4 speed. Maybe Summit, Jegs and whoever elses web site will have that info. Or look at the manufactures web site or call them. I may have just got lucky, I didn't know it mattered. What is the difference. I know the starter is different, but not enough to effect the headers. I still have the mount for the clutch peddle, it is above the header. |
Originally Posted by gfrench
(Post 440958)
Its still a 350, cam, carb intake, exhaust and your not in the low hp range any more. They fit fine, and its flowmasters or your a noob. If you really broke they make some knock-offs, but get flowmasters. But I've actually decided I'm going to go with (and save up for) an Edelbrock top end kit (heads, cam, intake, new carb and do the headers and exhaust when I'm doing that. So for now I'm just swapping a test pipe for my cat and probably throwing on some flowmasters. |
Originally Posted by NYH1
(Post 440951)
(Post 440959)
Really? I didnt? I am using the same headers with a turbo 350 as I did with an M22.
