Intermittent lost communication issues
Old Mar 13, 2023 | 12:22 PM
Williams1977's Avatar
Default Intermittent lost communication issues
I have a 12 Chevy camaro Rs/Ls at 160,000 miles that occasional get a lost communication code U0401 invalid data symptom 71. It doesnt do it all the time but does it when I stop at a light or idle and idles rough after the symptom. I used a multimeter to checks ohms, can high and low and checked my voltage i did have a bad battery but i changed it yesterday but still having the same problem. I also did a tune up coils and spark plugs with correct gaping check for vaccum leaks haven't changed injectors yet because I dont want to start changing things and it turns out it wasnt the issues. I used my big scanner to look over things one thing I forgot to mention I have a permanent code p305 I check misfire data and misfire data keeps misfire and this rough idling makes the stabilitrak icon light up here and there at idle and abs/speed sensors are ok I've been racking my brain has this happen to some of the camaro owners?
camarofanboy88
Jan 8, 2017 12:06 PM
altereddoug
Jan 2, 2011 05:49 PM
baurwin
Jun 2, 2009 03:24 PM
Foxracer117
Aug 5, 2008 08:50 PM
johng_nj
Jun 21, 2007 12:20 PM
