71 camaro vin decoded
Old Jun 27, 2024 | 11:17 AM
71monster's Avatar
Default 71 camaro vin decoded
hello i was wondering if any of you 2gen Camaro guys can help me out decoding my vin on my 71 Camaro
vin# 12487IN562246
Old Jun 27, 2024 | 11:48 AM
Only thing it tells you that you don't already know is that it is an original V8 car and it was built in Norwood,
1st- 1 GM
2nd- 2 Camaro
3rd- 4 V8
4th&5th- 87 Coupe
6th-1 Year 71
7th- N Norwood (plant location)
562xxx Seral number (IMO you should not post your hole Vin number online. No one needs to know the Serial numbers and it could be used to track your car.) I do not pretend to know how someone could use it against you I only know a PI can find out everything about you based on your vin assuming your title is filed with your State. If a PI can do it I am sure a scammer can also. .
If you want more details you want to decode you trim tag (AKA Cowl tag)
https://www.chevy-camaro.com/chevy-c...ecode-1971.php
"The trim tag is riveted on the driver's side of the cowl under the hood."
Kris77
May 3, 2021 07:22 PM
jorgem2
Dec 23, 2017 08:33 PM
maskedman
Aug 15, 2010 08:19 PM
JoJmoto
Aug 28, 2007 11:49 PM
projectszero
Jul 25, 2007 01:15 PM
