Wiper linkage
Old Jun 13, 2007 | 10:11 AM
srmrvette's Avatar
Default Wiper linkage
I have the same problem as another forum member over a year ago. Replaced the wiper motor on my '99, now the linkage won't stay together. The link uses a plastic cup that snaps over a ball. Does anyone know of a source of parts that could fix this. Please help....it seems to rain every day!
Old Jun 13, 2007 | 08:09 PM
t9ojetpilot's Avatar
Default RE: Wiper linkage
[X(] while ive not had to deal with this issue with my car yet it sound like i will have to at some point. you may try checking the dealership for replacement arms with new plastics in them or try ( if its possible, like i said i havent dealt with this yet) and see if the setup can be replaced with spherical rod ends. ive used this very successfully in other applications when i was forced to deal with old brittle plastic parts that were costly or no longer available. this would most likely take some mechanic and fabrication skills but will eliminate your reliance on expensive or non existent parts. hope this helps kurt
Old Jun 13, 2007 | 10:47 PM
srmrvette's Avatar
Thanks, Kurt, for your advice. I talked to a friend who is a GM tech, and he even came over and fixed it! When you are connecting the linkage you hear a click and the two parts are connected....for a while. You need to push them together harder, until you get a second click. Then they are really connected. He says they do not have much problem with these, even with years of use.
MBlac649
Aug 4, 2012 10:31 PM
x01660
Aug 1, 2011 03:31 AM
MelloYello
Jul 1, 2011 12:52 PM
derekstl
Dec 1, 2009 04:33 PM
quckrnu
Dec 21, 2006 05:22 PM
