Window Crank Handle Removal
How do you remove the window crank handle? there is no screw on the front and there is no cap on in the front. i dont feel a screw in the back either. I tried twisting and pulling on it but i dont want to break it.
There is a kinda U shaped clip on the back side. It is either open parralel to the arm or opposite. Try sliding a rag in behind it and pulling on both ends. There is a tool for doing it but if you can't get the handle off you must not have the tool.
O
O
Try to picture that as your crank. The top is the handle you grab to turn it. The U shaped clip will either be u or n under the bold part.
O
O
