Gear Shift Handle Removal??? How???
I have just accquired a nice 1972 Camaro. However, the carpet is worn completely out,..so I purchased a new carper kit. My problem is,.. can't figure out how to remove the gear shift leaver so I can remove the console, allowing me to install the new carpet. This is an automatic with the correct double handled shift leaver. How do I remove this shifter??
Thanks in advance,
Danny
Thanks in advance,
Danny
yeah take the consol out . and disconnect the shifter cabel and the 4 bolts and shes outta there.very easy. but if you want just the *** off you. u take a think screw driver and pop the button off and than with a plair of plyers u sqeeze the clip and it comes off. good luck with it man
There is two or three screws under the center councle glove box open the lid and there is a couple of screws holding the box in remove the screws and you should see the screws at the bottom and also there is a screw in front of the councle under the dash there a should be some kinda bracket there with a screw remove that and the councle shoud come right out
