What to look for?
Old Mar 1, 2007 | 01:32 AM
TheStig's Avatar
Default What to look for?
Hi, Im looking to buy a '93 - '97 Z28 and was woundering what problems are commen and what I should look out for.
Also what engines are avalible in the car?
Thx,
Old Mar 2, 2007 | 10:26 AM
cplthomas's Avatar
HELP ME TOM CRUISE
Yaaarrrrrr
Default RE: What to look for?
If this was a ford forum we would have a long list of things that are common problems, hahahaha. Any ways engines avail for those years were 207, 231 or 350. All with the different trans types.
Old Mar 3, 2007 | 11:06 PM
toml14's Avatar
The biggest problem with 93-97 Z28s is the optispark distributor. (Do a search in the LT1 forum and you will see.) The z28s only had a 5.7L 350 V-8 called the Lt1. Transmissions werea manual 6 speed(t-56) and automatic 4 speed(4l-60(e)). The engines are very strong and will run a long time if they are properly maintained. Look around for oil leaks from the oil pan, intake manifold and front timing chain cover. Make sure the electric cooling fans are operating correctly. Other than that just check the normal stuff you would on any car. Good luck ...they are great cars!
[/align]
