What is a good xenon hid conversion kit?
What is a good xenon hid conversion kit for under $150 i dont want plug and play because i have heard they suck and i enjoy wiring :P
I don't want a bad kit that will break quick. I have a 96 v6 camaro with stock headlights currently.
Its a mtx jh1200 (class d) so it has 1200 rms i have wired at 1ohm streetwires and stinger hpm series 1/0 gauge wire.
Class d is good, you should be good. I've installed in my uncles navigator with 4 tv sets and 2 t1000s and 400/ 4 jl and no prob. If you have problems just pay the 5 bucks and make a relay
Just search 9006 bulb xentec on eBay. You will need to remove old bulb and replace using silicon. I recommend red high temp silicon because the heat the bulb makes. There is a tutorial floating around in this forum on how to install. It is overall pretty easy.
