weird noise ??
Old Nov 11, 2007 | 07:43 PM
Saint_Ali's Avatar
Default weird noise ??
well my 93 z28 makes a weird noise now around 2k rpms its kinda like a ticking noise, it doesnt make it at idle just sounds normal, even if i hold the gas past 2k+ in neutral it doesnt make the noise its only when its in drive, the exaust sounds normal, it only makes the noise when im accelerating it doesnt make it when im coasting...any ideas ?
Old Nov 11, 2007 | 08:10 PM
bluovlh8er's Avatar
Default RE: weird noise ??
comming from the motor area or..............
Old Nov 11, 2007 | 08:20 PM
Saint_Ali's Avatar
yeah sorry it sounds like it coming more from the drivers side of the car maybe towards the front wheel
Old Nov 11, 2007 | 09:04 PM
Chappie99's Avatar
Possible rod bearing? Maybe exhaust leak?
Old Nov 11, 2007 | 09:22 PM
Saint_Ali's Avatar
i dont think its an exhaust leak, my oil pressure has been fine it hasnt dropped at all, its been at the normal psi, and i havent lost any performance at all
Old Nov 12, 2007 | 12:53 AM
tonkabully's Avatar
take a broom handle and hold it to each headerpipe at the flange, then put your ear on the other end,if its internal you will be able to hear it crystal clear.it could also be your fan hitting your shroud,especially if its a flex fan or the shroud has shifted.
Old Nov 12, 2007 | 11:00 PM
95slvrZ28's Avatar
I had a horrible exhaust leak and I never experienced a decrease in oil pressure or performance. You can only head them when the engine is under a load because the exhaust doesn't have enough pressure to squeeze out the smaller gap where the leak is, so don't rule it out.
Old Nov 14, 2007 | 12:45 PM
Saint_Ali's Avatar
yeah i checked the fan and seemed ok, thought it might have been the cold air intake tapping but that wasnt the case, yeah i was thinking exhaust leak or maybe a bad injector
Murda99v6
Sep 30, 2010 09:56 PM
TEXASMAN1
Jun 12, 2008 04:45 PM
biohazard
Jan 7, 2008 05:47 PM
davidalvarez82@hotma
Oct 28, 2006 03:28 PM
LS Series Tech
Sep 9, 2006 08:45 PM
