v-10
Old Apr 24, 2007 | 03:58 AM
vampyrico's Avatar
Default v-10
if by some act of god someone had the money to buy a v-10 viper engine. would it be possible to put it in a camaro without changing out everything that made it a camaro? because its common knowlege that camaros arent sleepers. i think that would be the first sleeper lol. so to speak.
Old Apr 24, 2007 | 04:01 AM
uncle bill's Avatar
Default RE: v-10
New LS7 bolts right in and makes the same power.
Old Apr 24, 2007 | 04:28 AM
vampyrico's Avatar
Default RE: v-10
i want it to say viper, and not corvette. thx for ruining my dreams lol.jk. thats pretty awesome tho. no way i could afford an ls7 or v-10 viper engine. ill keep dreaming. drop a t-600 in it. get 800hp easy. no tranny, just on and go lol. drive shaft right to the rear end. lol. we will simply need a throttle cable where the gear shift would go. and a tachometer out of a leerjet. wieghs about 400lbs tho i think. been a while since i touched one. itd be cool, people would mistake your exhaust for your intake.
Old Apr 24, 2007 | 04:36 AM
uncle bill's Avatar
Default RE: v-10
That's cool, keep dreaming..............
Old Apr 24, 2007 | 01:21 PM
badinfluenceRS's Avatar
Default RE: v-10
V8 Dawggg
anything is possible with enough money...I've seen a 455 in a FWD converted to RWD compact Cutlass Ciera
Old Apr 24, 2007 | 11:13 PM
Lee Willis's Avatar
Default RE: v-10
If you have enough money you can do anything: GM's research group once put a big Ferrari V12 in a Firebird and made it run well (they had all the money they wanted).
The Viper installation would be a challenge, and interesting, but I think the car would be nose heavy unless you knocked back the firewall and intruded quite a bit on the driver's compartment to put the two "extra cylinders" behind the normal eight rather than ttake the easy way out and put them up front, using a split radiator and narrow accersories set to gain the roo needed for the engine being about 6 inches longer.
An LS7 makes the same power, as someone observed, and weighs less, and most important will fit without hassles.
Old Apr 25, 2007 | 04:33 AM
chrshadil's Avatar
Default RE: v-10
Hey with wanting it to say viper just get some decals it's amazing how many ppl don't know a v-8 from a hole in the ground. I got this friend that has a little stock CRX and he has put triton V10 plastic decals on his fendor. I asked him to race and my other friend in the passenger seat said "Dude you can't beat him, he has a Triton V10" he argued for about an hour that it had a V10 dumbass but funny.
Old Apr 25, 2007 | 06:33 PM
microkid's Avatar
March 2011 ROTM
Technical User
Default RE: v-10
for the wieght of that engine, it isnt worth the effort. and if you want the fron of the engine and belts sticking out of the front, and keep a firewall, it wouldnt be possible
