Tune-Up?
First of all, with a Haynes manual you can do about everything needed yourself, and a huge saving. Even doing it yourself the parts you need could easily be over $40, but at most shops you would be very lucky to get out for a century note.
Both above post are correct. For the 30 - 40 buck range you might get just an oil and lube job. Also you need to know what exactly is a tune up, these days some would consider just changing the oil and filter to be good enough. plugs, timing (yeah I know newer cars dont need timing adjusted) filters, wires, etc...
tedandangie
07-09-2008 12:06 AM
