tires
Old 01-10-2006, 07:56 PM
bowtieguy's Avatar
July 2009 ROTM
Default tires
i have a 78 camaro .what size tire can i put under the rear without any rubbing issues.i have the stock rearend in it.the body is factory and has had no mods. to allow for bigger tires.i would like to put 295/50-15 under it .also what size rim will fit under the rear.with 50 i would like to put 10" rims on them.maybe put 60's mounted on 8" rims on the front.any help would be appreciated.
Old 01-13-2006, 12:31 AM
v8chvyguy's Avatar
Default RE: tires
I have air shocks and 255/60r15's on 15x10 reverse offset cragars on the rear of my '79 Z. They rub if the air shocks get to low. If you can get the offset right a 15x10 rim fits good with a 265/60 maybe a 275/50 but that would be pushin it. I highly doubt you'll be able to get 295's under there without having to mod something. I've noticed that wide tires suck on anything other that dry pavement. As soon as I find factory Z wheels I'm wrappin them in some 235/65r15 rubbers and sayin bye bye to those ai shocks and the low traction tires they're protecting.
Old 01-13-2006, 01:16 AM
bowtieguy's Avatar
July 2009 ROTM
Default RE: tires
igot a 454 in this car and when stomp it ,it automatically goes sideways and i thought that big meat in the rear would help.do you have any suggestions on how to keep a car in a straight line on a heavy take-off.sure would appreciate it.so your saying a 60 series tire is about as wide as i would want to go .iappreciate your help.
Old 01-13-2006, 02:41 AM
78 LT modified's Avatar
Default RE: tires
i have a 78 with 255/60/15 on 15x8 (85 model z28 wheels) no rub at all, no air shocks or anything, it will mainly depend on back space of the wheels you choose, if you figure out how to put on a 295 let me know. good luck
Old 01-14-2006, 02:23 AM
v8chvyguy's Avatar
Default RE: tires
I measured mine once and I think I figured that a 3.5" to 3.75" backspace would fit a 15x10 perfectly. my reverse offsets I have now only have 1.5' to 2" backspace. I'm saying a 265 should fit and a 275 might fit. Keep in mind that the rear end moves from side to side in turns more than you may think. The three digit #(265) is the section width, the two digit #(60) is the aspect ratio, basicly the sidewall hieght. As for making it hook up, I think it's possible to go to wide as it is also possible to go to narrow. If you have an open diff, only one wheel spins you sideways, I suggest installing a limited slip or a locker. Thorsen and Auburn make very good limited slip units and Detroit makes the best lockers. The other key is wieght transfer, when you launch you want as much wieght transfered to the rear of the car as possible to help traction.
Old 01-16-2006, 03:13 PM
bowtieguy's Avatar
July 2009 ROTM
Default RE: tires
i sure would appreciate any info from anyone .any tips on how to make this car go straight.it has stock rearend with factory posi-trac and370 gears,traction bars the cheap ones.subframes are connected.tires are 205/14,i havent bought tires yet .these tires are just to make it a roller.also 245,265,275 and so on is the height not the width.75,70,60,50, and so on is the width not the height.a 255/60 is shorter than a 275/60
Old 01-17-2006, 12:51 AM
v8chvyguy's Avatar
Default RE: tires
A 255/60 is shorter because its not as wide as the 275/60 compare it to a 275/40 or 45 and you'll find they are within a quarter to half an inch in overall height. the section width dictates the sidwall height hence the name aspect RATIO. on a 255/60 the sidewall hieght is 60% of the section(tread) width. I appologise if I failed to mention that I've been selling and installing tires for the last twelve years, and I work in a driveline shop solving problems like these.
Old 01-17-2006, 02:34 AM
bowtieguy's Avatar
July 2009 ROTM
Default RE: tires
point taken,i appreciate anything you can give me
Old 01-18-2006, 01:49 AM
bowtieguy's Avatar
July 2009 ROTM
Default RE: tires
come on guys give me something to work with here(LOL).i want to know what i can do with the stock rear suspension,so i can get better traction and run a better line.i'm low budget and can not afford to put a 4-link or a 3-link suspension under this car right now
Old 01-19-2006, 02:27 PM
v8chvyguy's Avatar
Default RE: tires
How much of a budget are you on? aside from a set of drag radials the only other mod I can think of is a locker or a spool. Either of which is a few hundred anyway, the spool may be cheaper but the car won't like turns. I cant think of to many cheap ($300 or less) mods for improving traction.
Quick Reply: tires
