timing mark
Old 03-30-2007 | 05:51 PM
vampyrico's Avatar
Default timing mark
cant find the timing mark on my 85 camaro. nno idea where it is or where to look.
Old 03-30-2007 | 11:58 PM
cplthomas's Avatar
HELP ME TOM CRUISE
Yaaarrrrrr
Default RE: timing mark
Which motor? the timing marks are typically at the harmonic balancer. There may be a piece of metal that pokes out away from the motor, if it comes to a point and that point is over the pulley then that is it. Are you going to be adjusting the timing?
Old 03-31-2007 | 04:25 AM
vampyrico's Avatar
its a v8. not adjusting the timing, but in the event that i need to, i would need the timing mark u know.
Old 03-31-2007 | 05:22 AM
74454bb's Avatar
May 2007 ROTM
It should look some what like this. http://www.careersnet.org/automotive...Marks%20GM.jpg
Old 03-31-2007 | 06:01 AM
vampyrico's Avatar
will i have to remove any parts to see it. cause its not exactly out in the open while next to the harmonic balancer or watever. the ac condenser, water pump, and alternator all shadow the crank. i will check tomorrow to see if its there. cant believe ive never seen that before. ever, on any engine. not lookin hard enough i guess. cant see somethin unless you look for it. i had a 89 dodge spirit for a while, and for a long time the engine mounts never stood out and i didnt notice em until i replaced them. now it was like thats the first thing i saw when i opened the hood.
Old 03-31-2007 | 06:21 AM
74454bb's Avatar
May 2007 ROTM
you may have to get a flash light, yours will probably be black and dirty, most are. .youll see a groove in the harmonic balancer . It's a good idea to markthat with a white paint pen. I cant find a good pic so I may have to snap some for you.
Old 03-31-2007 | 06:48 PM
TW62T's Avatar
If possible, jack the car up, put it on stands, and have someone bump the starter. You would be able to see it and get to it better from underneath. Then you can clean it and apply some white paint for later use.
tmatte
04-20-2011 06:01 PM
EdPDX
07-15-2010 06:18 PM
86CamaroZ28
06-12-2010 06:29 PM
robdog
82-92 V8 Tech
07-11-2009 08:58 AM
cyclesofnothing
06-26-2008 03:05 PM
