tie rods and ball joints
If you do it yourself, probably less than $100 in parts, if you get it done probably $250-400. You will need a wheel alignment after u change these parts. While you are doing one side, you should be thinking of doing the other side olso, as the wear out about the same. If you going to get it done get some estimates from some repair shop chain (Pep Boys, Minike, Sears, Bear, etc..) and get some free estimates and take it from there.
