stumble at 2k rpm update
Old Nov 12, 2008 | 12:23 AM
max1995's Avatar
Default stumble at 2k rpm update
I took my 95 3.8 to a friend to get the codes read, and got code P0302 (misfire detected in cylinder #2). I checked the coil for spark spark plug #2 and found that the terminal was all rusted as well as the inside of the spark plug wire boot, so I changed the wires and the coil and I haven't had stumbling problems at 2k rpms since. One other wire besides the #2 plug wire was cracked and it looks like some one tried to fix it with electrical tape...oh and I changed the fuel filter too. The car still shakes a little when going to 3k rpms, but passing 3k rpms it seems fine, was wondering what that could be. I got these two other codes along with the first one I mentined, they are P0147 ( heater circuit malfunction for o2 sensor 3 in bank 1), this car has 4 o2 sensors (1 at each side of the exhaust manifold, 1 before the cat and 1 after the cat) is it the one right before the cat. And code P0108 ( manifold absolute pressure sensor or baroetric pressure sensor input is higher than expected for the current operating conditions) . Thanks
Old Nov 12, 2008 | 07:58 AM
02StanGT's Avatar
Default RE: stumble at 2k rpm update
O2 sensor you mentioned is the one after the cat. I would check out your MAP sensor for the other code. It is located on the passenger side of the intake manifold towards the back of the engine.
Old Nov 12, 2008 | 01:10 PM
sammyjo's Avatar
I would have to say the misfire is the fuel injector for cylinder 2 so you may want to check those
Trio3b
Dec 13, 2012 11:53 AM
1993_Z28
Feb 8, 2012 05:01 PM
backinac
Aug 13, 2011 11:21 PM
max1995
Oct 24, 2008 10:57 PM
blue94z28
Jun 22, 2005 10:35 PM
