Sagging door
Old 03-09-2005 | 06:54 PM
intrepid340's Avatar
Default Sagging door
Hello, I just purchased an 88 Berlinetta from the boyfriend of a neighbor. It is the first Camaro I have owned so I am not familiar with a lot of things about it. It is not in too bad of shape and I am starting to work on getting it fixed up for my granddaughter. The drivers door sags so it doesn't shut properly. It does not appear that there is any adjustment at the hinges. Am I going to have to replace the hinges?
Paul
Old 03-09-2005 | 06:58 PM
nj85z28's Avatar
Senior Administrator
February 2012 ROTM
May 2012 ROTM
Default RE: Sagging door
that might be one way to do it, if the hinges are that worn out
Old 03-10-2005 | 01:39 PM
DarkBirdZ28's Avatar
there is a company that makes rebuild kits for f-body door hinges. basically when that usually happens it means the pin is warn and warped. if'n I were you look int getting rebuild kits for it or get a whole set up.
Speener
10-04-2014 12:59 PM
PEESKI
05-12-2012 12:19 AM
CheVy_R0aRrR
06-08-2011 02:39 AM
CamaroKid16
09-15-2008 10:12 PM
MotoFreak195
10-31-2007 02:55 PM
Quick Reply: Sagging door
