Please Help
Old Nov 28, 2007 | 09:11 AM
the_matrixx's Avatar
Default Please Help
I have two tech questions on my 97 Z28. Hopefully someone on here can assist because I don't have the tools to figure it out myself but I would like to fix it myself.
1- My turn signal lights don't always flash when I use them; they stay "on". It's both directions but there isn't anything consistent that I can see as to why. The hazard lights always function correctly though.
2- My driver side window doesn't roll all the way up or down in one motion. It stops going either direction after a second or two, then I have to wait for a few seconds and push the button again.
I really hope someone on here can answer these. I'm thanking whoever in advance if so.
Old Nov 28, 2007 | 09:24 AM
bluovlh8er's Avatar
Default RE: Please Help
the window need a motor. its time consuming and a pain to do, but its do-able.......
Old Nov 28, 2007 | 10:02 AM
02StanGT's Avatar
If all the bulbs work, then you need a new turn signal flasher module. Easy to replace, though it's under the dash and you have to contort yourself a bit to reach it.
Old Nov 28, 2007 | 10:17 AM
thanks. i'll check it out
