Please help 1986 Camaro
Old Apr 16, 2009 | 11:35 AM
Joshmc1986's Avatar
Default Please help 1986 Camaro
I have a 1986 Chevy Camaro w/350 4 barrel edelbrock.It sounds like it is missing.Have replaced the ignition module, cap, rotor, plugs, wires,checked spark at the plugs and is good. But when running and remove wires from 3, 4, 6, cyl makes no difference in running. What else could be wrong.Thanks for any answers.
Old Apr 16, 2009 | 06:51 PM
Compression test?
Old Apr 16, 2009 | 08:51 PM
Joshmc1986's Avatar
I checked the compression on 2 of the cyl's that appear to be not firing and they are at 150 psi.
Old Apr 16, 2009 | 09:44 PM
If you get spark, fuel and compression you have fire. It might back fire but it has to fire. How did you check the plug? Could the new plugs be cracked? Was this a problem before you replaced all those parts? What do the plugs look like? Black? white? brown?
Old Apr 16, 2009 | 10:09 PM
Joshmc1986's Avatar
I replaced the parts trying to solve the problem. Plugs are oily. I checked spark with tester and removed the plug and grounded it. It has a good blue spark. The problem started when my positive battery cable grounded out.
86Z28Cam
Jan 29, 2014 06:04 PM
ROADBLOCK
May 12, 2007 03:56 PM
thatguyoverthere
Jun 27, 2006 08:20 PM
1986camaro2.8
Nov 1, 2005 05:35 PM
