Optispark HELP!
Old Dec 25, 2007 | 06:38 PM
luvmysccamaro's Avatar
Default Optispark HELP!
i got it a little bit wet while washing the car, but enough to make it shake violently. will the water dry away and if yes, can i speed up the process?
Old Dec 26, 2007 | 07:19 AM
williesrepair's Avatar
Default RE: Optispark HELP!
Maybe.
My first thought would be if using a high pressure washer you could have caused a plug wire to split or pull slightly loose.
Or when washing a wire and or plug that where marginal (still firing, but carbon tracking slightly) to finally go fubar and now you'll start getting a miss, and eventually a check engine light with a random misfire code (P0300) or a specific cylinder code.
You also could have introduced water into a specific sensor on the engine and now it is sending a improper signal to the PCM, and the motor is being adjusted, incorrectly, because of the false signal.
MAF sensor wet, if any water managed to get into the air intake. Coolant sensor soaked, they are notorius for having harness failures, Possibly could have split or slipped a vacuum line off.
Visual inspection is the first thing to do before touching anything. LOOK at what could be wrong first.
And, you could need to go beat the snot out of it and it will dry off.
Old Dec 26, 2007 | 01:48 PM
98ss4REAL's Avatar
from one lt1 owner to another ditch the optispark and go buy a optispark delete kit trust me been there done that
Old Dec 26, 2007 | 02:26 PM
were can i get one, how much is it, and how much to install it?
Old Dec 26, 2007 | 02:29 PM
will these do the trick?
Old Dec 26, 2007 | 02:48 PM
98ss4REAL's Avatar
look it up check out coil conversion or optispark delete i havent seen it sence i sold my lt1 but they are out there....the ones i seen still use the optispark but for a diff reason and use coil packs from the ls1 it might be costly but no more optispark problems... or go buy another msd optispark and spend 550 and hope u dont go in any water..... p.s i went threw 2 msd optisparks in 2 months then sold my lt1 so its on u.....
Old Dec 26, 2007 | 02:58 PM
so will these work and if yes which is the best?
http://www.delteq.com/
http://www.geocities.com/reilym/LTCC/
Old Dec 26, 2007 | 03:03 PM
02StanGT's Avatar
I've heard of the first one from Delteq. Those will work. Not sure which one's the "best"
Old Dec 26, 2007 | 03:37 PM
Heard good words about the Delteq, don't know about the other. In any event, the internals of the Opti are still being used in both systems. This means that you still need an opti with good internals to make the multi coil systems work. The only thing different, as far as the Opti goes, is that the high voltage spark is removed from it, and with it the ozone production. This should keep new internals from getting corroded, but wont help if you start out with bad ones.
Old Dec 26, 2007 | 04:04 PM
98ss4REAL's Avatar
there ya go, i like the first one, looks good and plug and play will make it easy for ya to put in or who ever u get to do it....
ricer_killaZ28
Aug 9, 2010 08:53 AM
Y2Keglide
Jan 9, 2009 08:13 AM
luvmysccamaro
Dec 28, 2007 01:19 PM
whitebread96
Dec 15, 2007 12:09 AM
