Open Plenum Tunnel Ram
Old Jul 30, 2006 | 03:14 PM
SickSickSick's Avatar
Default Open Plenum Tunnel Ram
ok here's a goody ... how in the heck do you adjust dual carbs with an open plenum tunnel ram? cut the fuel off to one carb and adjust one at a time that way? sick
Old Jul 30, 2006 | 07:06 PM
Default RE: Open Plenum Tunnel Ram
the answer is time and patience LOL. i think i finally got it adjusted. sick
Old Jul 30, 2006 | 10:10 PM
MadMikeZ28's Avatar
I saw your post and thought I watched Bob at Spartan engine development do it many times before. I geuss I should have paid attention to what he was doing.[:@]
Old Jul 31, 2006 | 11:34 PM
In the old tripower days, we used a synchronizer gauge on top of the carb and adjusted the air screws so that each carb sucked the same amount of air at idle. Then adjusted each mixture screw the same amount, a little at the time. Took quite a while and the adjustments needed monthly touch ups.
Old Aug 1, 2006 | 12:22 AM
yea i'm still running a little rich. the cutting off fuel to one doesn't work. someone needs to invent a devise for dividing the plenum when adjusting. would make things alot easier. sick
izayuhgawd
Dec 9, 2011 03:57 PM
osduck5
Mar 5, 2010 01:07 PM
osduck5
Jun 5, 2009 07:00 PM
jrm2389
82-92 V8 Tech
10
Sep 11, 2008 08:23 PM
92camaroRS
Mar 14, 2007 09:34 AM
