Oil Leaks
Old Mar 19, 2007 | 03:07 AM
chrshadil's Avatar
Default Oil Leaks
1994 Camaro Z28 conv. My car makes that burnt oil smell when you get on it. I think it does that because the oil is dripping on to the exhuast pipe. I have changed the o-ring in the oil cap tube (the part that threads into the valve cover not the cap) it was leaking around the bottom of the cap tube,and I'm in the process of changing the valve cover gaskets (got drivers side done still need to do passenger side). If that don't work what else could it be?
Old Mar 19, 2007 | 11:44 AM
blackz87's Avatar
Default RE: Oil Leaks
Main seal on the engine.
Old Mar 19, 2007 | 12:28 PM
chrshadil's Avatar
The timing seal or the rear main seal??
Old Mar 19, 2007 | 07:00 PM
RatMotor's Avatar
What about the tranny? Do those newer ones have a vent tube? Could be blowing out that.
Just a thought..
RM
Old Mar 19, 2007 | 09:58 PM
Run your hand at the rear of the engine where the intake manifold meets the block. This is a common source of oil leakage. The oil leaks down the back of the engine and is often confused with a rear main seal leak. PS, don't do that on a hot engine, hurts fingers. lol
Old Mar 19, 2007 | 10:19 PM
chrshadil's Avatar
Just got the valve cover gaskets on, stoped what I can see, but I think its also leaking behind the harmonic balencer. My oil pressure went up to a little above the have way mark it was sitting at a quater above 0. Is this good or bad that it went up.
Old Mar 19, 2007 | 10:40 PM
The valve cover gaskets should make no difference to the oil pressure, they are not part of the pressurized system.
Old Mar 19, 2007 | 11:31 PM
chrshadil's Avatar
What would make my oil pressure go up like that
Old Apr 3, 2007 | 09:11 PM
chrshadil's Avatar
There is a puddle behind the intake manifold on top of the tranny and its oil. So I guess i'm gonna change the intake manifold gasket if there anything else that could be leaking back there.
Old Apr 3, 2007 | 09:18 PM
cplthomas's Avatar
HELP ME TOM CRUISE
Yaaarrrrrr
The heads have gaskets as well. You would probably end up changing the intake gasket anyways, it has to come off to get to the head gaskets. Might be a good idea to get a complete gasket set and do it up. Oil coming from behind the HB is an indicator of a spent front main seal.
