Non Cranking 3rd Gen
Hello, I am new here and need a little help, wondering if anyone has had this problem, thanks everyone.
I put a new battery in about 2 weeks ago, car started fine, I went to start it yesterday and nothing. I have full battery power, the car wil not crank, I turn the key and the security light blinks and goes off just like normal. Here is wahat I have investigated so far..
- Fuses - crank, ECM, all other
- Anti theft relay clicks (looks like it opens and closes) VATS
- I have not looked at the ignition switch yet - volt meter to see if the switch is stuck open
- New Battery cables
- neutral safety switch
Pete, I am having a brain fart here, where is thst located?
Is this also called the anti theft relay? (VATS) Behind the kickplate on drivers side? it has four wires going to it
