Need help finding date code on 327
Old Aug 12, 2013 | 05:56 PM
Milan's Avatar
Default Need help finding date code on 327
I cant seem to find the date code on the block. Front right is this # J157975 F1026RB
Left back under the head is 3782870
I thought there was a date code next to the block casting # but I cant find it. Is it in another spot?
Thanks
Old Aug 12, 2013 | 06:39 PM
Flint motor plant 10 (October) 26th assembly date. The RB suffix code tells it's a 1962 327, 300 h.p., hi-perf. mated to a manual trans, from a full size car (Impala, etc.)
Wouldn't hurt to keep looking for the casting date, just to make sure there's no conflicting reports: Camaro Decoding help on Chevy-Camaro.com
Old Aug 12, 2013 | 06:49 PM
Milan's Avatar
So I started looking at passenger side behind the head and found this on the block. Had to ue a mirror so I hope I read it right.
1-5-6.
Old Aug 12, 2013 | 08:10 PM
Your casting number 3782870 is 1962-65, or other sources are showing it to go up to 67.
That alone would suggest the 1-5-6 might be the casting date. Make sure you're seeing a 1, because the first digit in the date would be a letter (I) not a number. But, I'm also finding the RB suffix code might be 1962-64, not just 1962, but not up to 1966. However the suffix code would still mean the 1/I-5-6 wouldn't be the casting date. See if you can find anything else.
Old Aug 12, 2013 | 08:15 PM
Milan's Avatar
Thank you, I will keep looking.
Old Aug 13, 2013 | 07:31 PM
Milan's Avatar
So after some more searching I found this. J123. So that tells me the date code is Oct 12 1963. You hear people talk about numbers matching cars, is there a way to tell which specific car this engine came out off?
Old Aug 13, 2013 | 09:03 PM
Casting date that late in the year means it was put in a 1964 model car. As I mentioned above, the suffix code means it was from a full size car, such as an Impala. And being a hi-perf manual trans application, I'd say an SS.
Randy Bilyea
Dec 29, 2012 03:56 PM
GT17319
Apr 13, 2011 08:18 PM
redrocket1989
Feb 10, 2010 03:00 PM
buckmaster
Aug 8, 2007 01:43 PM
