Low level light
Old Mar 20, 2006 | 01:40 AM
my2ndcamaro's Avatar
Default Low level light
Anyone....Help. its driving me nuts....I just picked up a 1994 Z28, no owners manual in the glove box. I have a dash light on. It looks like a low level indicator. It has a arrow pointing down with what looks like a fluid under it. WHAT IS IT...ALL FLUIDS ARE FULL, IS IT A SENSOR GONE BAD? WHAT FLUID IS IT FOR?...
Thanks in advance..
I'm going to search ebay for an owners manual next....
Old Mar 20, 2006 | 02:16 AM
94Z28SHAKER's Avatar
Default RE: Low level light
i believe it is your low coolant light, try to flush and refill your coolant system, and make sure there are no air bubbles by opening the bleed screw until its a steady stream of coolant, even if your coolant seems at a good level it could be dirty and messing with the sensors.
Old Mar 22, 2006 | 05:58 PM
If that doesn' fix it, pull the electrical connector from coolant level sensor, short the two wires toghether with a paper clip, and the light should go out. If the light stays on you have a wiring/connector problem. If the light goes out the sensor module is bad, you can try clening it, or better yet replac it. It is located on the top right of the radiator.
libertyforall1776
Apr 23, 2015 03:48 PM
Terry
Dec 31, 2012 07:28 AM
96PacecarZ28
Aug 31, 2011 12:07 PM
evilbeef54
Jul 27, 2008 09:47 PM
CamaroX69
67-69 V8 Tech
Jun 24, 2008 10:36 PM
