injectors
Old Jun 7, 2007 | 08:56 PM
8485Chevycowboy's Avatar
Default injectors
off hand anyone know what the stock injectors r on a 97 z28 lt1 350??? ,
Old Jun 7, 2007 | 09:10 PM
t9ojetpilot's Avatar
Default RE: injectors
[X(] ill assume you mean thier flow rate in gph and unfotunately i dont know that number but ill guess somewhere in the mid twenties. a high performance website with injector sellers should be able to tell you the stock flow rate as they will be more than happy to sell you thiers that flow more. most stock v8 stuff is often in the mid to high twenties with the performance versions well into the thirties and maybe forties. please dont make the mistake of thinking that injectors alone are a good idea and should only be considered as part of a package that includes upgraded air intake, throttle body, exhaust etc. you will do damage to if you dont consider that you have to be able to move the increased flow of air and matching fuel increase through the motor. kurt
Old Jun 7, 2007 | 09:38 PM
thanks for that info and no i wasn't going to just do them alone but i thought I might want aheads up so if i c a good deal i might want to pick up but thanks anyways. cj
Old Jun 7, 2007 | 10:09 PM
28 pounds, if I remember right.
Old Jun 8, 2007 | 12:48 AM
[X(] i just found a source that lists them at 24.9 lbs/hr. hope this helps kurt
Old Jun 8, 2007 | 03:24 PM
thanks guys that does help!!!!!!
lt1z2896
Mar 6, 2010 05:52 PM
Cris
Jan 24, 2010 03:48 PM
joeSScamaro
Sep 4, 2007 02:49 PM
8485Chevycowboy
Jul 11, 2007 03:45 PM
sepadowd
Jun 15, 2007 08:50 AM
