i have this problem
Old Jul 4, 2007 | 09:05 AM
bluovlh8er's Avatar
Default i have this problem
would a plugged cat make the car bogg out untill like 3000 rpm then you can feel it kick in? but NOT set a ses light on.
i did a full tune up with no luck.
Old Jul 4, 2007 | 10:09 AM
Default RE: i have this problem
A clogged cat will make things worse as engine speed increases. Most times when an engine bogs it is due to a fuel problem. Do you notice black smoke when you push it from a dead start? You may want to check the fuel pressure and pressure regulator function.
Old Jul 4, 2007 | 10:15 AM
bluovlh8er's Avatar
hey pete, no black smoke, but i did run out of gas recently maybe the fuel filter is clogged.
Old Jul 4, 2007 | 10:27 AM
srmrvette's Avatar
This is when one of those $49.95 code readers can pay for itself. The computer knows where the general problem is, you just have to have it tell you. The paper clip thing could work, but with my bad eyes I would probably miss a blink or two.
If this was on an engine with points I would blame the settings, as I have encountered the same problem. But that isn't the case here.
Old Jul 4, 2007 | 02:43 PM
MadMikeZ28's Avatar
What Pete said. Change the fuel filter. Could not hurt.
And the $49.95 code reader will not pay for itself if it did not turn the "Check Engine", "Service Engine Soon" light(s)
Old Jul 4, 2007 | 03:46 PM
srmrvette's Avatar
Madmike, maybe I am finishing your sentence, but my reader can turn off the SES light. My '99 SES light came on. Bought the reader, it said no codes were set, I erased, and the light stayed off. I had been through several cycles of start, run, shut down, and my guess is that the computer removed the code but could not turn off the light.
I would have a tough time finding a shop to do this for $50, so I say it has paid for itself already. Hope I don't need it again, but if so, I have it....
Old Jul 4, 2007 | 08:48 PM
bluovlh8er's Avatar
i do have a obd2. there isnt a code though.
IROCYOURVTEC
82-92 V6 Tech
Oct 20, 2010 01:01 AM
Beest
Jun 27, 2010 02:42 AM
IZZY1967RS
Jun 15, 2008 11:11 PM
2lucke4u
Sep 1, 2006 09:55 PM
