I CAN SEE MY TORQUE CONVERTER!!!!
Old Jan 10, 2007 | 10:54 PM
microkid's Avatar
March 2011 ROTM
Technical User
Default I CAN SEE MY TORQUE CONVERTER!!!!
and the fly wheel too. its on my 86 z28 tpi, with a brand new 700r4. tranny fluid seams to be fine (light amount past the full line, bright red). i noticed it because i was inspecting my lights and heard a click noise and though maybe it was my exhaust, looked underneth and saw the bright blue converter spinning. its on the passenger side, and is an opening about half an inch to the top, and gets narrow to a close at the bottom. what can i do to fix this? is there a rubber seal, a metal shield, or is my tranny about to fall off?
Old Jan 10, 2007 | 10:58 PM
shnormo's Avatar
Default RE: I CAN SEE MY TORQUE CONVERTER!!!!
Usually there is a transmission dust shield.
Old Jan 11, 2007 | 12:55 AM
79maroman's Avatar
is the bolt holding the dust shield coming loose? gone? sounds like you have a shield, but that it is coming off at one point. if you have a digital camera, take a quick snap-shot, and we'll be able to tell you.
Old Jan 11, 2007 | 02:43 AM
MadMikeZ28's Avatar
The tranny case around the converter and flywheel is at an angle from the tranny pan to the bottom of the block. There should be a plastic cover that fills in the rest of that area.
Old Jan 11, 2007 | 11:28 PM
microkid's Avatar
March 2011 ROTM
Technical User
i will take a look tomarrow and if i cant fix it, ill take a pic. i think my car spends more time on jacks than it has been driven
Old Jan 11, 2007 | 11:31 PM
blackz87's Avatar
Replacements cost about $25
Old Jan 14, 2007 | 01:57 PM
microkid's Avatar
March 2011 ROTM
Technical User
where can i get a replacement? i checked on jegs with no luck.
Old Jan 14, 2007 | 02:15 PM
Chevy dealer, they have all the parts.
Old Jan 14, 2007 | 03:15 PM
blackz87's Avatar
Any good Transmission Shop, it is a standard item for all 700R4 autos.
Old Jan 15, 2007 | 06:25 PM
microkid's Avatar
March 2011 ROTM
Technical User
i finally got chance to get underneth and look. its just missing a bolt from the plastic peice. anyone know what size it should be?
jrgearhead
Jan 24, 2012 01:25 AM
tscw96
Dec 27, 2011 09:54 AM
DeathProof
Jul 29, 2011 03:55 PM
freaky
Mar 13, 2010 12:28 PM
samtron
May 15, 2009 09:07 AM
