how much power?
i have a 350 2 bolt main from a 82 truck- stock bottom end lunati cam 480lift 292duration edelbrock 650 carb and edelbrock rpm performer. how much power do u think this will make.
i also have another altinater can i hook this up with my other 1 or do i need 2 batteries? thanx!
when i time this engine do i line up the 4degrees before and then put the distributer a@cylinder1 firing>?
If you are using the truck heads, the engine will be limited by the design of the truck heads which are strictly set up for low end torque. If you were to use good aftermarket heads or good production heads, such as GM Vortec, 350 flywheel HP would be easy.
Why do you want to use two alternators?? But if you really want to that, you can hook them both up to a single battery, but don't put them on the same single V belt as it won't be abble to carry the load when both alternators max out.
PCweber
07-11-2012 06:13 AM
