How do i change the Airbags
Old 04-05-2007 | 07:22 AM
Blocke99ss's Avatar
Default How do i change the Airbags
My airbags were blown---I got a new pair of bags outta another camaro- do i need to find a sensor somwhere in the car? is it the one under the console? how do i know if that is need to be replaced. anyone know anything about airbags! gimme some info <3
Old 04-05-2007 | 09:41 AM
Blade's Avatar
June 2007 ROTM
Default RE: How do i change the Airbags
not sure how to do but make sure u unplug the battery first and then under the dash their are connectors that u have to unplug i know thats first.
Old 04-05-2007 | 11:25 AM
williesrepair's Avatar
Unless you have the proper scan tools and diagnostic equipment your going to spin wheels. Impact sensors, mounted front, side and rear need replacement. Bags of course. Reset and learn procedures may need to be done considering the year (OBD1 vs. OBD2)
Your also most likely going to have to replace some of the column parts. The ring sensor at the base of the wheel...
I'd bite the bullet if I where you and get it done by a professional body shop. Your asking for a unexpected deployment if you don't get everything correctly installed.
Old 04-05-2007 | 03:36 PM
MadMikeZ28's Avatar
I always had good luck replacing just the bag. Even though Insurance adjusters took the same classes I did on restraint systems that told you to replace all the sensors they would never want to pay for them unless they had visable damage.
There should be two sensors up front and one in the middle maybe under the center console. The air bag stuff has yellow wire loom/tape and connectors. Also the center and at least one of the sensors up front need to be activated for the bag to deploy.
Old 04-05-2007 | 04:23 PM
I have also seen just bags work. But I'd hate to see him have a issue that causes more damage or a predeployment. Not saying it will happen, but it can.
It may be economical for him to have it squared away by a body man/shop once the body/frame/and paint are fixed up.
Old 04-05-2007 | 05:37 PM
Blocke99ss's Avatar
yea i have a donar car same year /but a z280 found the air bag sensor in middle of seats under the console on the donar car- and i was told the bags on driver side nad passenger both have sensor built into the bag units them selfs.... can any one confirm this?
Old 04-05-2007 | 07:04 PM
MadMikeZ28's Avatar
Its been a while since I last worked on a wrecked Camaro but I seem to recall sensors up front behind the bumper cover on the frame rails maybe.
woodstock
04-15-2012 05:44 PM
ryguy425425
01-28-2011 10:33 AM
Metaz
10-26-2009 09:11 PM
lucky14
05-16-2007 12:08 PM
BIOHAZ
01-09-2007 04:42 PM
Quick Reply: How do i change the Airbags
