horsepower
horsepower
I have an 88 camaro with a 305 bored .60 over with flat top pistons stroker crank head ported h beam rods high flow oil pump high rise edelbrock intake with a 650 cfm carb what kind of horsepower am i looking at with this set up?
RE: horsepower
No final compression ratio, no cam info "ported heads" with no flow value, "Stroker crank"no info no way to estimate HP.You put all that in a block that has a tuff time with 300 HP? I like the stroker 305, add torgue to a light casting, Normaly the casting flexs so much you just spin a bearing, But you might breakthe castinginhalf.
After this blows get a 350.
