High RPM miss
High RPM miss
I started having a miss in the high RPMs. I replaced the cap and rotor on the opti spark. When I put it back together it had atleast one dead cylonder. I started to tear it down I pulled the heads no problem there the block and rotating assembly are per fect. I took the fuel rails off and found trash in the injectors could that have been my miss?
RE: High RPM miss
high RPMs within the factory rev limiter. The injectors did have trash in them I haven't taken the filter off but I think it is the factory filter. So I'm thinking it may be corodied on the i nside.
RE: High RPM miss
No I didn't check the fuel pressure I thought it was the opti. So I tore down the front of the motor at a friends shop and replaced the cap and rotor ,but it took a while when I put it back together the dead cylider(s) started. I only had real trouble at full throttle before. The opti had signs of miss firing and wear I guess the the injectors where cloging when I tore into it it set for about a month with me only working on my car when someone was in the shop. I think either the trash in the injectors settled or the opti was firing so much better it was starved for fuel, but I didn't drive the car enough after replacing the opti to show signs of running lean. Will the stuff inside the housing of the opti itself go bad and cause these problems?
